digitech jamman question
  • Thread starter Thread starter bennym1219
B
bennym1219
hey
anyone know a way of getting the exact same tempo for two different loops.
eg: i record a loop in storage space 1, then a wanna do another loop for storage space 2, but i want it to be the same tempo as the loop in storage 1.
thanks
from the manual
Copy a Loop to a Different Memory Location
1. Stop any playback or record activity using the STOP/TEMPO footswitch.
2. Select a memory location that contains a loop (either the LOOP or SINGLE
LED is lit).
3. Press the STORE button. The DISPLAY and the STORE button LED flash.
4. Turn the SELECT knob until an empty memory location is selected (the
LOOP and SINGLE LEDs are off), or press EXIT to abort.
5. Press the STORE button again. The loop is now copied to the new memory
location.
NOTE: The Clear and Overdub Undo/Redo functions cannot be performed
after a Store/Copy procedure.
after copying the loop to a new preset, you can delete the existing loop info, and the tempo should remain intact...
