C
chestwick91
Whats the difference between tube amps and valve amps?
chestwick91 said:Whats the difference between tube amps and valve amps?
Richard Monroe said:It's the samme as the difference between an elevator and a lift, a truck and a lorrie, a cop and a bobby. Sometimes we really don't speak the same language.-Richie
I think that's correct, but then there's the "Valve Reactor."astoebe said:maybe he means valve state? which means there's a tube for the preamp only i think (correct and explain as necesary)
chestwick91 said:Stupid brits
rayc said:GGun,
GGood spiel.
But the truth is that the valve amp is actually a way of turning this on at higher pressure. You put a valve amp in your water tap (fawcettfarrer) & as well as reducing hammer is amplifies the amount of water that can run in a given time....
If you have too much difficulty speaking english then get your own language.Outlaws said:Stupid brits
Exactly.
Its not because of any ValveState thing, the English just like to call tubes Valves.
choconutjoe said:If you have too much difficulty speaking english then get your own language.
soundchaser59 said:Is that how it behaves?
