G
guttadaj
Howdy, folks. I'm having a problem that I can't figure out and could use some help. I noticed it when I tried to use the SONAR (using version 3 Studio) tuner. I got a popup that said "M-Audio Delta ASIO Analog In 1 Delta-AP [1]: The specified device is in use. Wait until it is free, and then try again." I have an Audiophile 2496 soundcard, and it's been working fine since I installed it about 6 months ago. I've just started getting problems like this recently, and I can't think of anything I've changed that could have caused this. Otherwise, I can record and play stuff back just fine in SONAR.
Another symptom of this outside of SONAR is when I try to run my Dell MusicMatch Jukebox, it doesn't give me its opening sound, and, when I try to play a song in it, it gives me a similar error to what SONAR is saying. It tells me "MusicMatch Jukebox could not access the sound card device, because some other application is or was playing audio. Make sure no other application is playing audio and then try to play from MusicMatch again." I can play songs in Windows Media Player, though. Very strange.
Anybody know what might be going on here? It happens right after reboot too, so I'm not sure what it thinks could be using the soundcard. Any and all suggestions welcome!
Thanks!
-Jeff
Dell Dimension 8200 - 2.4GHz w/ 512M RDRAM - using Windows XP Pro (SP1)
Thanks!
-Jeff
Sorry to hear you're having this kind of problem too. Keep me posted on what ends up fixing it, and I'll do the same.
