Albertm
Member
I have delay with guitar notes. If I turn off Input Echo or Audio Engine button the delay stops. But then I can't use plugins like Amplitube. So the guitar is dry. No matter what buffer or latency setting I use for sonar or Tascam 1082 board it wont go away. Drivng me nuts. And Ideas?
Setting
Sampling rate 44100
Buffers in playback que 2
buffer size 11.6
i//o buffer size 512
WDM driver mode. seems to work best with tascam.
I tried many different settings, I must be missing the idea here.
When i check mon/mix on tascam, delay occurs in computer mode, not input mode. So I believe problem is with Sonar. Help . Thanks Albert
Setting
Sampling rate 44100
buffer size 11.6
