Confusitron
Thanks for the advice. I have changed my mind for the most part. The mixer will be used for the PA and not recording, not unless I just feel like recording us. Most likely, we'll start off with maybe a 20 channel powered mixer. I think we'll be excluding the subwoofers for now and just be working with two standard cabs.S0C9 said:Confusitron,
At the risk of preaching some.......
I think you need to re-think your focus on an FOH board for live recording... First, most live recording (at the pro level) does not come from the FOH board. There's usually a snake splitter feed to the recording board, just as there is to the monitor mix. Why ? 'cus live boards are designed for gigs and not recording.
If you ABSOLUTLY have to have recording from your board, consider a 4 or 8 buss console. You are not going to get a quality recording from a 18 inputs to a 2 channel mix out, not unless your a darn good experienced engineer, and they are few and far between, and live AIN't Memorex. It will be OK, but not up to CD quality. Sure, lay down your click tracks that way, but come back and individually track later !!
Let's take a reality check...
2 guitar - 2 channels max (If needed)
4 keys - again, 2 channels max (you don't need stereo, and no-one tell the difference anyway. It's a nice to have)
7 drums (NOT !! - you can get by with Kick (AKG D112 or Audix D12), Snare/Hat (SM57) and 1 overhead (maybe 2) - so 4 at most
1 bass
1 percussion
5 vox - do you have to have all 5 or is it an ego-thing with the band... We do 4-part in our band, and that's hard enuf to separate... AND... how the heck are you going to provide monitor mixes for all these folks from ONE console ????
OK, that said, that's 15 channels loaded thru the PA. On club gigs, you can probably cut out the 2 guitars...
Now, figure out what your budget is... every one has a limit..
Start with venue size and work back... Clubs ? OK.
Speakers: - Full range (not bi-amped, $5-600 ea)) Yammy S215V, JBL JRX125's or Peavey SP4's.. If you got to have sub's that going to bump the price quite a bit...but Yammy SW115V ($399 ea) - two of each)
AMPS: - for speakers above, Crown CE2000A2 (660w into 4-ohm stereo)- $650, or QSC RMX2450 (750w into 4-ohm stereo)- $590, or Crest CPX2600 (750w into 4-ohm stereo) - $550. TWO - if you Bi-amp as the second will run the subs, and then you need a cross-over too ($200+)!!
Now you're up to:
2 PA speakers (approx. $1200)
1 AMP (approx. $600)
Total: $1800.
If you bi-amp:
2 Subs speakers (approx. $800)
2 AMP (approx. $1200)
1 Crossover (approx $200)
Total: $3400
And we haven't even talked consoles yet - which you're going to need something like a 24-channel A&H GL2200 ($2000+ USED on Ebay)..
You will save yourself a lot of money if you can get buy with it 16-chan console - you can even get a 4-buss one quite cheaply. There's some good ones out there, but SPEND the money on a good board - an A&H or a Midas... It will be well worth your effort. Do not buy Behringer or Mackie (except the 16's) for live work...
OK. !! So, roughly $4000 so far....
and we haven't even talked monitor mix, monitors, monitor amps, snakes, etc.
See where I'm going ?
This post is long, because I went thru the same exact process 2-months ago. Take a good hard look at what you want to spend, and unload, setup, tweak, tear down and load again every gig !! KEEP IT SIMPLE and NOT TOO HEAVY !!! It get's old in a hurry.....lifting and setting up all that gear every night![]()
Keep your costs manageable. You'll be glad you did. Buy the basics first and add other stuff as you go. Do NOT spend all you have saved.
You'll always need something else - got speaker cables ?? Speakon or 1/4's ??. Do you have a 1/3 Octave Dual EQ ?? You'll need one for the monitor mix, and possibly one for FOH. You may need Compressor(s) for bass, kick, snare and vocals ? How about an Antares ATR1 for vocal pitch correction. What ? You don't need pitch correction ! Your five vocalists sing 5-part harmonies and nail every one, every time. Sure.....Right on... every band should have at least one - set up as a channel insert. Nobody is perfect...
Hopefully this gave you some food for thought
Steve
I actually have a deal available to me right now... The deal includes:
(1) Yamaha EMX 5000 - 20 channel powered mixer
(2) Nady SPA850 power amps (with custom 8 unit wooden rack)
(2) Peavey SP 2 speakers
(1) Yamaha SW215IV subwoofer
(2) Speaker stands
I can get all of that for around $2000.
I can imagine that mixer is fine for our needs. How are the Nady power amps? Knowing Nady's reputation for their products, I can't imagine they're all that great. I could probably do without the subwoofer, so should I take it and resell it? As I see from the suggestions already in the thread, the Peavey SP2s seem like good speakers.
What do you think of the deal? We'd be picking it up ourselves, so there are no shipping charges.
