Or even better, a good quality outboard parametric. With a parametric eq, you can adjust the band width, which achieves the goal with the least amount of negative effects, compared to a graphic eq.
Thanks all for the help. Maybe it was that I wasn't applying the correct attack and release. I'll give it another shot,..or two,..or three,............
The eq I'm using is an Alesis M-EQ. I dont have any parametric EQ's. Will be getting soon I hope.
Thanks for helpin' me try and figure this out. Much appreciated.
Using the sidechain/compressor method should be prefered as the attenuation will ONLY take place during the "SSS". Using an EQ will be a permanent move, sometimes it works but while minimizing the "SSS" you will be also taking a great deal of other important frecuency stuff, such as the brillance in a vocal track. Just take your time to experiment Calwood... you'll get there for sure
