7string
Ok, I discovered something and am not sure what it is. I use GT 3 Pro and when I right click on a bus or channel meter a box pops up with a bunch of things in it. I checked the manual but there's not much detail so if anybody can add some insight to this I'd appreciate it. Here's what I got:
12 db Range
24 db Range
42 db Range
60 db Range
78 db Range
90 db Range
What does all this mean? It is currently checked at 42.
Now, I looked a little more and found the playback meter is set:
Peak
Post Fader
42 db
Record meter:
Peak
42 db
Bus meter:
Peak
Post Fader
42 db
Are these settings ok? Should I change anything? I'm assuming they are ok as the are the defaults or at least I'm assuming that too.
HELP!
12 db Range
24 db Range
42 db Range
60 db Range
78 db Range
90 db Range
Peak
Post Fader
42 db
Record meter:
Peak
42 db
Bus meter:
Peak
Post Fader
42 db
HELP!
