Am I reading it wrong, or do you need a driver installed in your computer?
Driver installs automatically when you plug in the TD-11. It installed fine, and I can see it under Sounds in the Windows Control Panel. In fact, we were able to record from it the first night we tried (although that happened AFTER it froze Sonar once first). But eventually we got it working fine for recording. Couldn't play back through it though.
Next morning I read somewhere about turning Local Control off in the TD-11. I did that, and I was able to play back with no problems (although didn't attempt to record again that day).
Then a few days later, we tried to record again. First up, we couldn't get any audio whatsoever out of the e-drums. Didn't make sense, since the audio is from a 1/4" jack, and shouldn't have anything to do with the midi. But I figured the only thing we touched was that Local Control setting, so I reset it to the original setting.
That fixed the audio. But couldn't get the midi to work at all. Sonar kept telling us there was no TD-11 device - even though there was. Then the drums would freeze. Had to shut them down and turn them back on to get them to work.
The manual is for shit. It has half a page on the usb port, and it mostly just tells you that the driver needs to be installed, and that it will install itself once plugged in. (Thanks for the help.
There aren't many controls in the midi section of the TD-11 settings. But the manual doesn't even address them, or what they are for. I only found the Local Control thing by going online.
There is a Midi Lock Setting, which we found (by trial and error) needs to be Off in order to use midi. There is the midi channel, of course - set to 10. Local Control. Note Chase. Program Change Tx, and Program Change Rx. No idea what those last three are for, but two are on and the Tx is off.
Again, however the only settings we ever changed were the Midi Lock and the Local Control, and we were to both record and playback, at least at one point.
There used to be Midi setting within Windows. But I don't see those any longer in Windows 10. As stated, the TD-11 shows up in the Control Panel, but it appears to be the audio portion, since it is group together with my Delta 1010 Sound Card settings. The Delta has midi ports, but I don't see them under Windows.
Of course, the other issue is we were doing this with the entire band present. So rather then waste everyone's time while we tried to figure it out, we finally just gave up. The drummer is coming back on Wednesday, and maybe with just me and him here we can get it resolved. Although, to be honest, I'm not even sure what to try and this point.
