presto5
What does a D.I. box do for a bass that my interface doesnt already do? I`m looking at the Radial passive Direct Box and its basically saying that it cleans up noise when recording...Isn`t that what my interface does?
A DI Box basically takes a high impedance unbalanced instrument signal (guitar) and takes it to a low impedance balanced signal allowing for longer cable runs without adding a lot of noise and also to plug a high impedence unbalanced sources into a low impedance balanced inputs such as a mic input. The radial DI passive boxes (or any other passive boxes for that matter) do this by using a transformer to step down the impedence
If your interface has a true Hi Z (Hi impedance) inputs then you don't really *Need* a DI box enless you want longer cable runs
An audio interface doesn't clean anything up, it allows you to record whatever it receives at whatever quality it receives it.
# Instrument Input
# Type: 1/4"
# TRS female unbalanced input impedance: 0.5 megohm....is this Hi Z or should I get the D.I.?
What interface are you using?
I`m using the Presonus Audiobox...thanks guys...just tryin to figure out what to buy..my heads spinning!![]()
The Audiobox only has Mic/Instrument inputs. Plug your bass into the front jack and start recording. No DI box needed.
You shouldn't hear a difference with a passive DI. You can get active DI's which you would probably hear a difference.
I would try your bass going directly into your Audiobox, first. Then if your not happy with the sound (and you probably will be) explore other options. I would get a preamp before I got a DI, but that's just me.![]()
Thanks man I appreciate the info...this site is cool!A DI Box basically takes a high impedance unbalanced instrument signal (guitar) and takes it to a low impedance balanced signal allowing for longer cable runs without adding a lot of noise and also to plug a high impedence unbalanced sources into a low impedance balanced inputs such as a mic input. The radial DI passive boxes (or any other passive boxes for that matter) do this by using a transformer to step down the impedence
