Cubase 5.0 prob
  • Thread starter Thread starter musician.thinc
M
musician.thinc
Hello, first time poster ......
Sorry to start off with a problem but hey you usually find sites like this due to technical difficulties .
Im running cubase 5.0 , which is new to me as i've had 3.7 for ages, but whenever i go to record anything (when i hit enable track) this crazy delay appears , everything you record has a delay on it, even if your just playing the guitar for instance you can hear a delay once you've pressed enable. I know it isnt my soundcard as everythings hunky dorey there , i think its sonthing to do with the audio set up in cubase , can ayone help me?
thanks in advance
I had a similar problem with 5.1.
I'm pretty sure I fixed it under:
Options>Audio Setup>System
Select "ASIO Direct Monitoring"
You may or may not have this option available. However, it's how I fixed my own delay problems.
Lopp,
I agree 100% ON THAT ONE, BUT DID YOU FIX THAT PERMANENTLY OR DO YOU have to do it every time you go to enable??...I have to do mine every time....
I dont have that option of direct monitering available, its in grey. sigh.....
Do you know of any other solutions?
Roker1 said:
Lopp,
Glad to know I'm doing something right. ;)
Each time I've used it, I've had to re-enable it. You may be able to permanently set it by enabling it and then saving the setting in your def.all song.
That's what I was afraid of. :(
I don't have such other advice aside from the fact that if you upgrade your soundcard or drivers or some other setting, you may enable that setting.
Best-o-luck. :)
Ok I fixed the prob, well my mate did anyway....still not quite sure what he did though. Thanks for all your help anyway
