Hey, I appreciate the reply.  Let me go into the setup a little bit.  I think it might be helpful.  I record the tracks dry, through the tape-outs on a Mackie powered
PMX2000 mixer, into a Fostex MR8.  Then I dump the tracks into n-Tracks using the card, and mix from there.
There is no bass (as such) on either of the songs, other than that provided by the guitar, so apparently that's part of the eq problem.  The guitar was recorded using a Sunrise Magnetic soundhole pickup, and I probably need to eq it more.  That's a pretty hot pickup, and perhaps putting a mic on it as well would help.  I probably had it panned to far to the right also.  I was trying to avoid putting everything right in the center, you know?
If you're used to hearing bluegrass style banjo, that could account for the "old string" sound.  This is an openbacked banjo with nylon strings, and is sort of supposed to sound "plunky".  Again, I'm sure you're right about the eq.  I've tried not to use much eq, since you read so much about it being overused.  The banjo is recorded using an sm57 strapped to the dowel stick (underneath the head).
I'm primarily a banjo player, so perhaps that accounts for having the banjo too loud in the mix.  As far as the vocal on the second song needing to come up, do you think it's because I put too much reverb on it, and that set it back?  Just wondering.  Also, it seems like if I bring the vocal up any more, I can hear some distortion at times, (clipping?)  But it's not reflected in the meters, if it is cllipping.  Maybe I'm just recording the vocal too hot?  I'm using an
SM86 for the vocals.
Again, thanks for the comments!  I know I have a lot to learn.
Nate
