antispatula
Active member
So I finally rewired a mic cable today, and checked out my mx5050 8 track to see if it worked, in a simple way. All I did was plug in a mic into one of the inputs, and talked into it, to see if it made the VU meter for the designated track move at all. So track 1 worked, so did 2 and 3. 4 did not. On the back of the machined is a switch for INPUT levels, and OUTPUT levels. So I guess it's for switching between mic and line level. So I played with the INPUT switch, while talking into the mic. Nothing. Then I flipped the OUTPUT switch, and the track worked! Then I swithed that SAME switch back to where it was, where it was when it didn't work, and it STILL worked. It's as if I woke up the track or something!
So then 5 6 7 worked, and 8 didn't. I played around with it, and it started working! So then I went through all the track just to re check them. NOW track 6 and track 7 aren't working, and I can't get them too.
So basically, 4 and 8 didn't work. Now they do.
Now 6 and 7 aren't working, when just a few minutes ago, they were.
What in the world is going on?!
And as a side note, I don't know all that much about electronics and equipment, since I've only gotten into it a little bit ago. What my side question is this: What does one have to do to be able to understand how to fix things like this? Like fix equipment. Is it electronics knowledge? How does one teach himself?
Thanks so much!
Thanks so much!
