G
I am in the recording techniques forum , right?
I kinda understand that you're seeing smooth waves and also jagged ones. I beleive you.
Thing is....what is the source and what is its signal path/chain beofre you look at it?
The only thing that should look like a sine wave on a 'scopre (analog or digital signal)...is a pure tone SINE WAVE.
If you're putting in a guitar track or keyboard tracks or any kind of audio tracks into the scope, YES, they will go up/down like waves but they WILL have sharp peaks and edges in the DAW, not smooth.....because they are not a pure tone sine wave.
So what kind of source signal *exactly* are you looking at in the 'scope...???
Again...you may be looking at one thing and thinking it should be something else and then drawing the wrong conclusion because you are seeing someting third....???
Yeah man, right forum. Just chill and get insight from others. 'Fuck you' is not taken personally.![]()
I blew , you caught me. My apologies, Sir.
It sounds like some of you are audiophiles, you don't think you would benefit from a device that can image a signal?
Jimmy , is gimme all digital? Anything on that page is real nice.
Greg is just....well, he's just Greg....don't let him fluster you, you'll get use to the LOLs.![]()
Not sure if this will help, look at your capture rate. Make sure it is something 16 bit 44.1 or higher. Maybe you have it set to like 8 bit which would degrade the signal. Look at your hardware setup and make sure it is at least 16 (you could go higher), 44.1 (This is CD quality) see if that helps you get closer to what you are expecting.I am at the beginnings of my digital recording experience. I suppose what your saying could be correct. I did make samples , these clips, but they are just for illustration. I should have just used a single chord being played. No effect. No accompaniment.
I need to prove that , what comes in is what comes out. I have tools to do this. Every other simple recording device in my house, even my phone can do this. It can come out stepped a little bit, fine, normal. This is all waviness removed and a sawtooth pattern replaced. Why doesn't that happen if I record a simple tone to phone, and analyse the mp3 on the scope? I originally thought this was a installation problem.
I am not satisified with the toneport performance. I cannot mix back anything, and reverb is nothing to do with it. I cannot A B the input and toneports output for you.
Room noise is the same 26 db avg
To say put away the scope, is not right.
I need to get the flat full signal recorded into the DAW, or as much of it as possible. Other people are obviously doing it.
It is being scoped out the phones port of the toneport
