mark4man
MoonMix Studios
Well...
I thought this was promised in version 5...but it doesn't seem to work for my feeble efforts.
I select a clip; & go to the copy dialog (Edit > Copy)...& I can't select Clip Automation without also selecting Events in Tracks.
The help files give a weird explanation:
[BTW - The idea is to have the clip envelope available for audio events re-recorded as "near identical" (e.g., a MIDI sequence, where a slight change is made to the MIDI data & then re-recorded as audio. 'Or' a mixdown of multiple tracks to one...where a slight change was made to one of the tracks & then the group was mixed down again.) Would be nice to then grab the clip envelope from the original & paste it onto the new clip.]
Where am I going wrong?
Thanks,
mark4man
Dell Dimension 8250 / Windows XP
Intel 850E Motherboard/Chipset
Intel P4 2.53GHz CPU (512 KB L2 Cache, 533 MHz FSB)
1024 MB PC1066 RDRAM
Ultra 60GB Primary HD / Single Volume (OS, Apps, Files/Folders.)
Maxtor DiamondMax 9+ 80GB Secondary HD / Single Volume (Audio Data only)
nVidia 64MB GEFORCE4 MX420 AGP
Echo Audio Layla 24/96 PCI Audio Interface
Universal Audio UAD-1 DSP Powered Plug-In System
KRK Rockit RP-8 Studio Reference Monitors
SONAR XL 2.2
SONAR5.0.2
WaveLab 5
So...I tried that (the last part...pasting the envelope only), but you can't paste the envelope without pasting the audio (&...I only want the blessed envelope.)You can copy and paste envelopes or parts of envelopes between tracks and clips. You cannot, however, copy and paste a clip envelope without also copying and pasting the audio or MIDI data that is in that clip. If you paste a clip envelope into a track without the clip that it came from, the clip envelope becomes a track envelope.
Thanks,
mark4man
SONAR XL 2.2
SONAR5.0.2
WaveLab 5
