Cool Edit not recording after new install
  • Thread starter Thread starter vulcanelli
V
vulcanelli
Hi all,
I have read several threads about Cool Edit not recording but none seem to have reached a resolution of the problem so I am seeking help anew.
While I haven't explored many of its functions I have used CE Pro 2.1 for several years without incident just recording and editing various audio files. Recently computer problems forced me to reinstall Windows XP. I put CE back on and now it does not seem to record using the same internal source not a microphone source.
I click record and select the default 16 bit waveform. Clicking record it says recording in the lower left corner, the track time line advances but no wave form appears and nothing plays back. I have gone into device properties and selected my on board sound device for wave in so I it should be looking at the right source. Is re-installing my only option left?
Thanks
Have you tried seeing if going under "edit" then "hardware setup" then selecting your recording source u are using would help...I dont really get your question, and Im using Audition 3.0, but they have kept the software features pretty much the same so you should be able to try that...Im not sure if that will help but, since no one wants to try to answer you, I figured Ide give it a shot.
recording problem
im useing cool edit pro 2.0 I have a problem i can only get the right side of my vocals to work when i playback and when i record ... theres supposed to be 2 peaks but i can only get the right side workin and im useing a m auido interface and i have went into device properties to put wave in and wave out and device order and made sure the use in [ev] was on any help would be a big one thank you..
