R
Radio Panic
Control room / studio room shape ideas...(from scratch)
Here's the scenario:
What if you could build a studio from scratch, without the constraints of pre-existing rectangular structures, and with the ability to build rooms in any shape you wanted?
These are the ideas I was bouncing around:
Pentagons-- Would regular pentagons be a good room shape? They're symmetrical (for speaker placement) and have no parallel walls, and seem almost ideal...(to the amateur.)
Circles-- I honestly have no idea how this would do acoustically, but seems like an economical use of construction materials and an efficient shape. That is, until you need to add anything flat to the wals!
This is all assuming that you've got a versatile and fairly massive construction material, and a fair amount of distance from neighbors, so sound containment isn't a top priority.
I've seen a few studio plans online, i.e. John Sayers' site, and I've noticed double doors/ walls between rooms are usually set at an angle to each other. Is this necessary mainly 'cause the walls are hollow...?
Any feedback?
Any feedback?
Done it myself, and I'm not a contractor with fancy equipment. However, care must of course be taken.
