Nizhny Tagil
Member
My multi fx pedal has a stereo/headphones line level out and a mono out that's supposed to be used to connect it to an amplifier.
So far, I've tried using either of them to connect it to one mono input of the audio interface (which has a switch to choose if it must be fed a signal that is line level or instrument level) through a normal guitar cable and then record on the computer.
I don't use stereo effects, so I'm fine with recording only in mono, and the sound I get isn't very different according to how I do it, but I was wondering what method is actually the best/correct one to connect the pedal to the audio interface.
Thanks.
Thanks.
