condenser ?s
  • Thread starter Thread starter lbcstudios
L
lbcstudios
hey...i need a mic for micing vocals and acoustic.. im not sure wat to get... must bbe less that 100 if possible... wat does a condenser mic do that most dont... why do they sound better? .. wat makes a mic sonud better than another... give a link if possible.. thhhakns
Check out Harvey's Big Mic Thread at the top of this page. It will provide you with a great deal of basic (and not so basic) info on mics.
As far as mics under $100, the SM57 is a classic dynamic that you'll never outgrow. Decent condensors in this range include the Studio Projects B1 and the Marshall V67.
I liked my V67 on vocals and acoustic. I like my SP B3 on vocals and acoustic, but I'm currently embroiled in a scandal about my B3, so I'd better not say anything more and leap to the crazy conclusion that a B1 might be a good buy as well.
Condenser mics don't always sound better... checkout the sticky BIG THREAD at the top of the board. With that said... there are a lot of different good mics you could get for about $100 or so that will work for you. But, to find out which one "you'd" like the best.... well, you'll need to audition them all yourself to find out. So, while your auditioning mics to find just the right one for you... make sure you checkout the AT4033 it's a great mic... and remember, if you buy used mics, you can afford more expensive mics. In other words... you can get more for you money.
Most of the time I perfer LDC mics for vocals, and SDC mics for acoustic instruments... but, if you want just one affordable mic for both, be sure to checkout the AT4033. Keep an eye on ebay, and etc.
Dynamic vs. condenser. Condensers aren't better, they're different. Dynamics generally have lower output, so they need a preamp that can give them some good clean gain. Condensers are generally more sensitive, which can be good for capturing the fine details of something, but they will also capture the fine details of music played badly in a noisy room.
Whether I chose a dynamic or a condenser as a first mic would depend on what I'm supposed to plug it into, and the room I have to use it in. If there's any background noise, a dynamic will usually be less critical. If you have a mic preamp, even a fairly cheap one, such as DMP3 or VTB1, I'd probably start with SM57 or AKG D770. If you're going into a digital recorder with phantom power, using the preamps in the standalone, I'd start with a condenser, like Marshall MXL V67 or Studio Projects B-1. Note that condenser mics require power fed back up the cable to the mic, called phantom power. This is provided by most preamps, and by most mixers, which contain preamps, but not by most soundcards. If you don't have a preamp, and you don't have a mixer, then you are going to need one. If you're using a digital recorder, it may or may not produce phantom power. The little ones usually don't.
So- tell us what you intend to plug this mic into, and you'll get better answers. Regarding the 4 mics I named above, I have confidence that they do what that type of mic does very well, for the money.-Richie
