SuicideNote
always improving
For a while now I have been contemplating the concept of “fixing the recording in the mix”. Now I haven't been recording music for a long time, but I can make a few observations based on my experiences and others that I have read about. I have probably invested 500 hours over the past 6 months trying to learn as much about recording as I can. Not necessarily because I want to be an AE or even to dabble with recording other musicians. I just have this great quest for knowledge and now my interests are focused on the recording process. Applying this information to my own home recordings is my primary benefit for any knowledge that I have gained. Anyway, on to the concepts and questions.
I have invested some money in recording software and plugins that might allow me to modify any sounds that I magically was able to capture. In addition to the computer applications, I also have a few hardware rack modules, that I can apply to sounds as they approach my workstation. It has been stated by many people, that you should try to get the “sound” that you are looking for right at the source, or at least by the time it hits your hard disc the track should sound the way it was intended to sound. Is any modification to the audio track after the recording process considered wrong? Is this fixing in the mix? If not wrong, at what point does a little level adjustment and track modification become fixing it in the mix?
Now during my little adventure to record my songs, I could decide that this reverb plugin is really going to benefit my song and I plan to apply the filter to a track or two after I record them. If you plan for plugin help, are you cheating?
I think that the “mixing” process officially starts the second you hit the stop record button. A lot of times (most times) I feel that applying a moderate amount of compression to vocal tracks after they have been tracked is beneficial and is much better sounding than hammering them before they get to disc with my hardware compressor. Does my hardware suck that much? Do my ears fail me? Or am I okay to do things like this?
I guess I feel that post-recording track modification is necessary to get the best sound out of my current equipment. Sometimes I will hear guitar frequencies that conflict with vocal passages or that cover up keyboard parts that should stand out. When I make EQ adjustments, did I admit a failure for this song?
Well, that's probably enough to get this thread started. Thanks for the insight.
