compressor/preamp
  • Thread starter Thread starter wasteddays
W
wasteddays
Hello everyone,
I am relativley new to recording and have a few questions. I am about to buy a dbx 226XL compressor, when I get it will I be able to use it on things that I have already recorded? Or will I have to use it when I am tracking? Also, how essential/beneficial would getting a good pre amp to go along with be? I'm looking at the presonus TUBEpre. I record onto a Tascam2488, and I know it has the built in preamps but would the extra one help? Thanks a lot!
Mike
You may be better off putting your money together and buying something a little better on one end or another.
Ive never tried the 226...used to have a 166, which was ok...but I would compare it to the onboard on that Tascam first. (I havent used those either)
I actually have a TubePre that I bought on whim a while back. Its got a few tricks...but again, I would compare it to Tascam first. Im not a big fan, personally.
With that said, you can track with outboard or mix with it....either way you mentioned will work.
Yes, a good preamp or a good compressor goes a long way....but if I had $250 and a Tascam, I would head on over to the microphone forum.
Good luck. :)
I had 2 of the 266xls. They are not a very good sounding compressor. I got rid of them and replaced them with the FMR RNCs. Much better and slightly cheaper.
That being said, You can still use a (outboard) compressor after the fact on prerecorded stuff. You would have to send the track out a dedicated output (direct out from tape deck, or hard panned left or right) and then record the resultant affected track to an open track.
Hope that helps.
tom
thanks guys
thanks a lot guys...I'll definatley look into different pres and compressors :)
