elbandito
potential lunch winner
Why do you use compression instead of "riding the fader" or, Volume Modulation?
I recently tried out Waves Vocal Rider (which is pretty awesome, btw) and after my trial period ended, I found myself playing around with parameter modulation in REAPER, using a gain/trim plug to try to emulate the functionality of the Waves plugin.
At one point, it occurred to me to try replacing every instance of compression that I had going on with my recent discovery of automated fader riding and found that the song really opened up, dynamically-speaking. Further, when it came time to stick a limiter on the master, the song didn't sound nearly as squashed as the first version that I had done.
Now, of course, one most likely wouldn't stop using compressors altogether in favour of fader riding but it seems to me that many of us are likely using compression to tame transients and keep all the levels in line... why not use automated fader riding instead?
So to sum it all up, when do you use faders/automation instead of compression and why? And conversely, when do you favour compression over fader riding/automation?
