O
		operationivy135
I am completely new to all of the recording stuff and i need help with the VERY basics. I simply want to be able to record my guitar and bass into audacity or mixcraft on a very cheap budget. I still need help just getting the noise (signal?) from my guitar through my effects pedal into my amp and then into my computer if that is possible.
What i would like is for my computer to pick up the sound i would normally hear the noise i would normally get from my amp after it went through the effects pedal.
I am using a les paul guitar, a marshall mg100fx amp, an rp225 digitech foot pedal, a behringer UCA202 audio interface with RCA to 1/4 adapters, and Audacity and Mixcraft as my software. I would not like to buy more stuff, and would like to try to work with my current hardware, but am open to new software.
My current setup (which i need help with) is:
Guitar > Effects Pedal > Marshall Amp > RCA202 Audio Interface > Audacity or Mixcraft
Is that the right way to do it? I need help on that.
Another problem: my marshall amp does not have a clear "output" jack. It has the input on the front, but the only others i could find were the "Send" and "Return" 1/4 jacks and a "Line Out" jack where you can plug in headphones. Which do I use as the output?
3rd Problem: When using mixcraft and audacity to record, what do i set as the input? On Audacity, there is Microsoft Soundmapper, Integrated Microphone, Stereo Mix and External Microphone. Which do i choose? On mixcraft, it allows me to use the USB Codec.
Please give me advice on what i am doing wrong, what to change, etc.
Thanks in advance
Thanks in advance
