clean signal layered over distortion
  • Thread starter Thread starter AFXSguy
David "The Tone God" Gilmour does the clean signal/dirty signal split, but uses two separate amps. Seems like that's what the Sparkle Drive approximates, which is good, since most of us can't haul around two amps. I believe I should check this out...
okay ive created a simpler setup idea to do this. what do you guys think of this is idea?
CLICK HERE TO SEE PIC
this eliminates any colouration of signal from mixer and DI box. then i can mic the amp. i read a vunch of reviews on the whirlwind selectors and they do not colour the signal. HOWEVER when you split the signal (using the both button), there is a little bit of signal loss. do you guys see this as being a problem?
You should never route your signal to an amp AFTER routing it through a DI.
