B
BigKahuna
The signal to noise ratio of the mic is probably what's causing the hiss. i.e. ... It worked ok for vocals,drums and amps because those are louder and you didn't have to increase the gain as much. With classical acoustic ... it's a much quieter instrument ... therefore you increase the gain, which in turn increases the noise/hiss. This is not only due to the mic, but also possibly the mic preamp in the SBLive. If you use an external mic preamp and then go into the SBLive's line input, you will get better results.
As far as $400 for a sound card ... you can get a killer sound card for that money.
