mshilarious
Banned
Indeed, but I figured it would show up the "most" noise. I certainly don't actually use it like that (hehe)... perhaps it's an unfair measure.
So each channel, in the mic preamps there is a 748 up front, and 3 x 4558s for the eq and other gain stages. The line ins omit the 748 but are otherwise similar.
In the main section there is another 2 x 4558s (for each side), one being used as a virtual ground (which I do not fully understand how that works) and one as the actual output.
Sadly all the 4558s (which is the bulk of them by far) aren't socketed, so I've gotta put some sockets in to try different ones. Ugh.
My initial plan is to socket the main output 4558s and one channel and try some TL072s in there to see what's what.
Does that sound like a decent starting point? Should I change the "virtual earth" op amps too?
Oh and thanks for all the info so far too!
Virtual earth is likely the summing amp, look up active summing opamp circuits for more info. I wouldn't sub in TL072 for 4558 as it's higher voltage noise. Really, the noise of 4558 should be OK anywhere except the mic input stage. I don't know the noise figure on 748.
I'm not into sockets, I would just swap in OPA2134 for 4558 and maybe OPA227 for 748. I am more familiar with TI parts; there are probably other good choices too. But I say pick 'em up front, solder them in and get on with your life. Watch the PSU as 2134 is a little thirstier than 4558.
You're probably too far into this now, but it's always good to decide up front if a recap & mod is really worth it or not . . .
