G
glynb
Balladeer
Blue Bear Sound said:If you guys are using your ears, I don't think that's a bad thing...
What I was commenting on was if someone is simply applying a preset for say Bass Gtr and not even analyzing if the track needs compression, or understanding if the preset makes any sense for that particular context.
Absolutely. I DO listen to what I've recorded and decide if it needs some compression, if it's bass guitar then I look up the idiot setting for bass and apply it. Now I must explain that currently I am always using the same bass, the same 6 string, the same keyboard, etc, so once I have found a setting that seems to work for the instrument I see no point in fiddling with the knobs each time all over again.
Of course in a recording studio situation where there are a wide variety of clients and instruments etc then I appreciate its absolutely essential to think about what settings to use for each and every case.
At least the idiot sheet acts as a starting point, then you can tweak it from there.
The explanation above was very useful, I think I nearly understand it now.
