Chameleon Labs 7602 Thoughts.
  • Thread starter Thread starter Warhead
Warhead
Warhead
Jai guru deva om
Fraserhutch, I thought it would be better to start a fresh thread here on the 7602 since the last one was (my fault) sort of pulled off topic.
The 7602 is heavy and well built. All of the wiring etc is neatly laid out in there, and the handy work looks good to me (I'm admittedly not real techy!).
The switches seem well built and turn with a solid "chunk", they used a gold contact ELMA switch for the mic/line selector (which would see the most use). Neutrik XLR, the D.I. jack is a Switchcraft. The cards are completely interchangeable with NEVE 1073 cards, of course vice versa. Having said that, there isn't one original part used by NEVE inside of this box.
The St. Ives transformers were reverse engineered and reproduced (to what extent I am not certain) in China, and so goes the rest of the list of parts in this box. Before anyone decides to hint that these guys are doing something evil here, remember that dozens of other companies are doing the same thing and making claims of "same spirit as Neve". The biggest difference with this company being they had the boxes built in China and they cost about 1/3 of competitors. OK maybe a little less than that.
I do NOT own a 1073 strip, and my friend (who bought 2 of these from us) has some NEVE preamps but I haven't bothered to do a side by side comparison as his were mainly broadcasting type of preamps. I do want to rent a 1073 strip and do a direct comparison in the near future, only to be able to hear for myself how close they got it. Until then I can only testify to what I hear as it stands on its own.
The preamp is very nice with a real vibe to it. I would say it is more all purpose than many of the sort of slower (and darker, mushier) response NEVE stuff I've been able to use in the past (very limited experience with NEVE). Concerning the mic pre, I've used it on vocals and drums so far, and can't wait to do some electric guitar work with it. The midrange is on the more aggressive side, with a seemingly small bump in the upper mids. Transients are well represented by the preamp as well, drums sound punchy with plenty of snap. The transformers don't seem to be overly distorting things either. The low end is full but not overly exaggerated.
The D.I. is smooth, think 70's bass guitar sound. The low end is quite full with well defined mids again. Turning the output down and the input up I was able to get some slightly pushed sounds and a nice range to work with before distorting noticeably. It really seemed to open up the initial attack of the bass by pushing it like this.
The EQ on the 7602 is very, very useful. This thing has balls, really the only way I can find to describe the sound. The high end (shelving) has 5 frequencies to choose from and unlike many EQ's sounds good when pushed! You can just slam an acoustic guitar tracks high end and it will open up beautifully without adding any harshness. The higher freq's can add some air up there, but it will be a more aggressive sort of sound still.
The mids have a fixed Q with 6 frequencies to select from, the Q is pretty wide and when it comes to the midrange adjustment I have found that a little bit goes a long way. You can get quite effective control with small amounts of cut or boost here, and of course radical if you really push it to + or - 18dB. You can completely gut a track or push it aggressively with an in your face sound as well. Very effective control, I found it nice especially on electric guitars, toms, acoustic guitars and more. On the cut side of things, the 360hZ can be just the trick for cutting some boxiness out of damn near anything.
The low end (shelving) has 4 frequencies to select from, and is again capable of + or - 18dB of control. You can flat out carve the low end off of anything with this, or boost it enormously as well. Again, think aggressive although of the 3 bands the low end remains the smoothest sounding of them all. Thick when pushed, not just louder, thick.
The low end filter does just what it says and is quite steep.
Things I Like:
First and foremost, the sound. It is a very good sounding box and has tons of vibe. It's not a super clean preamp (although the noise floor seems very low), but it's not dirty enough to where you'd say it changes the sound of the original source drastically either. Good vibe with some bite.
Tons of gain! (+80dB)
Line level use.
That EQ is so full of character though it's silly good, you can pump some real flavor in your sound.
I like being able to drop the output and push the inputs as it will open up the sound. It also acts as a fader for riding vocals during tracking.
I like the fact that it has a real power supply.
I like the sturdy feeling of the switches, and the fact that (aside from individual EQ band gain stages) it's fully recallable.
Things I Do Not Like:
It's made in China. Now, it is bringing this preamp / eq to the home and project studio market which is great but I'm never excited when anything is built in China because I personally wish everything could be built in the good ol' USA. But, wish in one hand...
The markings are little dots and are essentially meaningless. This is a NEVE characteristic and all of the cloners seem hip to this. When I'm writing down settings and I have to write "acoustic guitar, 3.4k shelf at +2.5 dots" I feel
strange! I wish they would have laid it out in actual dB increments.
The layout is virtually identical to the Chandler LTD1. This was pointed out to us by a Chandler dealer, and we not being familiar with the Chandler line looked it up and damn there it was. I called the folks at Chameleon Labs who said as far as keeping it at a 1RU design that style of layout made sense but they made no claims to borrowing from Chandler in particular. Having looked around a bit more the Aurora NEVE clones are laid out very very similar as well, the Vintech X73 being similar in a reverse sort of fashion, and so on. Which begs the questions about the chicken or the egg, or the clone or the clone resembling another clone, and also that they are not the same devices. Chandler is using many actual original parts and are not manufacturing in China.
It could have been prettier. I don't think it's ugly, but it could have been jazzed up more! At least they didn't use the red chicken head switches like
most other cloners!
All of the calls I'm getting about "does it sound just like a 1073" when I haven't compared them yet. OK nothing to do with the unit, but there's an awful lot of conversation being had about it being identical and even if they're not identical in sound...this is a great sounding box! Chameleon Labs isn't making any actual claims on their site or anything of it being a 1073 but it's certainly implied and it's what they're comparing it to at trade shows etc. I really do want to get a 1073 in here and spend some time side by side.
So that's what I think in summary. These guys are working on a tube pencil mic that should be out in a month or two (NOT a clone!) that we're interested in hearing as well. So Chameleon is working on other things.
War
Can the EQ be accessed seperately? Is there an insert for a compressor? If there is, is this before the EQ?
J
No, it can be used as line level though, or D.I., or mic preamp level but not simultaneously. There is no insert. The unit consists of a front panel 1/4" instrument input, XLR mic in, XLR line in, XLR line out.
War
Thanks, War, that's really helpful, and I think my buddy will be thrilled.
I assume this is what y'all are talking about.....
I heard the unit, side by side, next to a 1073 back in March. I was extremely impressed and thought it was just slightly, very slightly grainier sounding. It is very similar sonically with the responsive low/midrange thing Neve is known for. It had similar response at the upper end to the 1073. The midrange was different, somewhat not as detailed as the Neve.
At the time, I remember thinking this was a very worthwhile box for someone on a budget, trying to get a high end sound. I was going to buy one except that the Neve Portico thing came along and I was sucked in.
Still, a very worthy contender especially at the price point.
Here's an update. I walked into the GC in Fountain Valley, CA today and lo and behold, they had a Chameleon racked and for sale. Looks like they are carrying the product going forward. Pretty good coup for a small start up company.
Always welcome news to a small dealer like us! :p
It's funny, from the time we started planning our new retail store we heard GC opened at the top of the state, then the bottom of the state, now they're coming to our town (Columbia SC) is what we hear. In all reality it may help us, because nobody in this town thinks about buying recording gear locally. Now they have choices, and it's all we do.
War
GC can be a good thing for you or a bad thing. Warren, you've got a deeper product line in recording so it might be a blessing for you.
I think the problem is that everyone right now is trying to grab as much territory as they can and put someone else out of business. I've heard different reports about the recording market but some smart people tell me different things about whether the market might be growing or shrinking.
Well, not to get too philisophical here, but there are really 5 sounds that the home market craves but has not been able to capture.
LA2A
UA1176
Neve
API
Convincing Tape simulation
There seems to be a race for who can get the nearest at the right price. I think the industry is very close and in the next few years most mid-range, project studios and many home recorders will have access to these sounds at a reasonable price. Chameleon is obviously in the running. I think there will be a blood bath in preamps in the not too distant future. There are just too many duplicate sounds from colored to clean. How do these guys stay in business? The volume can't be that great, or the margins are still astronomical.
The sound of many professional grade mics is a little harder to attain in the lower price ranges but there are some really remarkable things from Audio Technica, Soundelux and a few others.
The next great frontier is low cost digital summing that simulates SSL and other big boards. I expect that race to pick up soon.
I do know that the mic pre marketplace for the Neve inspired mic preamps is at the wrong price point to gain big numbers. Some would say this is a good thing. The numbers are in the hundreds for manufacturers (hopefully) for a year's production if not lower (less than 100 per year). You don't get economies of scale. Plus, if they had levels of distribution, then costs go up.
