cdarchitec
  • Thread starter Thread starter nostromo
N
nostromo
why when I use cdarchitec to burn my projects, always the last tracks (11, 12,13 etc) are in trouble?
I burned it at 4x, 8x, 12x, 16x 24 and 32 x and always I get the same problem.
is the cdarchitec or the discs?
thanks
thanks
I thinks it's just you man, I don't have that problem. Only oneword of advice tho. Burn at 1X for best quality.
Which version of CD Arch are you using?
I agree with krimson. You should burn at a lower rate, if possible.
I'm using version 5.
SPINSTERWUN said:
Try burning at a slower rate.
I've burned using 10x (my burners max) as well and I've had no problems either.
CD Arch rocks!
:eek:
Sorry, about that, krimson.......
I quoted the wrong post-er.
spin
It could be the discs, it could be the burner but it could be your motherboard (via chipset suck) too.
I burn 40X on a plextor with CDA 5.X all the time...no problems...
SoMm
