Cubase SL2
MI4 media panel (4 inputs at 44100Hz. 1 input when set to 96kHz)
Computer with plenty of power.
I'm having problems getting a signal into Cubase when I try to set the sampling rate to anything higher than 44100Hz.
I can get a signal at the MI4 panel -the level meter LED's move. So I know that I'm getting input into the interface. However there is no signal on the level meters on the track in the project window in Cubase.
If I do NOTHING in a project except change the sampling rate to and from 44100kHz to 96kHz in the project settings I can record from the Input A (as required) at the lower rate, but still nothing at the higher rate.
Am I missing something simple here?
