Can't hear Logic guitar effects and record at the same time
  • Thread starter Thread starter VincentvanG
V
VincentvanG
Hi,
I just started with recording my guitar and voice with my Behringer X1204 trough logic pro, and so far it works pretty good but I have a problem too:
With my X1204 connected trough usb on my computer, I can record my guitar. But logic only hears the guitar when i put the ' 2-TR/USB TO MAIN' button off. If I turn it on, logic can't hear my guitar. But the problem, if I turn it off -so Logic hears my guitar and can record it- the sound from my computer doesn't goes to my monitors, only to my headphones connected to the X1204. With the result I can't directly hear guitar effects from Logic trough my monitors, only after recording.
Does anyone know how i can get the sound from Logic goes to my monitors but also enables to record in Logic at the same time?
Sorry if this isn't very clear, hope to hear from someone to figure this out.
I have logic pro 9 and this seems like a strange problem. one thing that I do is run a mix through bus 1 (in logic) and they put it to whatever output I want it on my interface. and then make sure you have the orange I button on the track active. (hope this helps but its a stab in the dark.
Doesn't seems to work here, still no sound from logic trough my monitors..
are your monitors hooked to your interface? or pluged into your computer? cause that might be your problem. on my logic system as soon as I turn on my interface all audio out goes through the interface (cause thats what it is) and interface for audio in and out.... try that.....(and......when you create the new track in logic make sure you have the in's and outs for what channels you want (on your interface) selected correctly for what you want.
long question short what is your chain of sound? check it start to finish and make sure it all makes sense. and even if it does change it and try something different.
