M
Mr Funk
You could always try a hyper-cardioid mic. This will help keep out other sounds, but you won't be able to move around as much.
The Electro-Voice RE1000 is great. Very neutral, but still quite flattering. It is a MDC condenser.
Always have the mic in the quietest part of the room, aiming away from the noisiest source. This may sound obvious, but people often get into the rut of always recording in the same part of the room (routine). It is quite amazing how just moving the mic can help with eliminating noise bleed and also acoustically.
Stick on a pair of headphones, crank the mic-pre up a bit and walk around your room until you find the quietest area. Then try some vocals to make sure that the acoustic is OK.
