Can reverb plugins be used for live singing? (real time)
  • Thread starter Thread starter mofat
Or are they only used in editing after recording?
Yeah, they can be used for live. There are two ways you could go about doing that. Either with a digital console that allows for use of plug-ins (essentially, a live control surface. Those will cost you around $30,000).
Or the alternative is bringing a laptop to your live show, connect your vocal mic into your interface, run the interface into your computer, run your vocals through your reverb plug-in, then send the vocals AND reverb out of an ouput on your interface (or two outputs if you want a stereo reverb), then send that to the main mixer in the venue.
Yes, but why? To what purpose? There are easier ways to get reverb on a live vocal, I would think... but depends upon what you're doing, or trying to do.
The OP's question says for 'live singing', so I assume he doesn't mean monitoring. The only issue is going to be latency - as long as you can keep that to a minimum via system settings, you do it.
