B
		Boseafus
Ok,
I have been using HS2002 for a few weeks now and really just got down to laying down multiple tracks up to 10. I have a P4 1.8, MSI 845G MOBO with 512 DDR memory, 80 gig WD HD, Win 98SE, Delta 66 with Omni studio and ALL the drivers are updated.
Tonight when recording vocals, I was getting random crackling sounds when I played the recording back. It was also kind of random. I would undo the track and try it again, and it would be fine. Yet, 2 or 3 more takes later...they crackling would be back. I couldn't figure it out. I thought it might be because I had too many tracks but I simply started a whole new session and the same thing happened. I was using my AT 3033 to record but I switched to a AKG C1000 and it still happened.
I will try to mess with the latency thing tomorrow but really have NO idea what I am doing. Should I lower or raise the latency. Should I mess the latency control panel in M-audio's software or the CW software?
Also, I don't know what type of drivers I am using. I think it's ASIO drivers but when I look in the CW options it only gives me PCM - Delta in 1/2 and a couple others (can't remember). Is the PCM the ASIO drivers? OR should it say ASIO in the CW options panel?
Thanks a ton.
Nate
Thanks a ton.
Nate
