Y
Yareek
Alright, either I'm a really good drummer or I have no clue what I'm doing.
I find that on my latest project, at least on the drums, I don't like compression on any of the tracks. And it's pretty edgy/aggressive rock stuff. I find the best results are from EQ'ing the tracks so they fit together, and then slapping a color comp like a Vintage Warmer on the drum bus to add a little grit and edge.
And I'm doing similar things with guitars except with a smoother comp. And for background vocals (although I do put about a 2:1 lower threshold comp on the vocal tracks to smooth out the levels because I'm too lazy to edit 50 tracks of them).
Is that a common way to mix? I guess it doesn't matter as I'm happy with the result. At the end of the mix, it needs less compression/limiting and it sounds a lot louder. I'm probably knocking off maybe a couple dB's on the instruments...it just seems weird.
