4
4tracker
Guest
Right now I'm using cheap cables b/c I just feel intuitively that fancy cables are a scam and a waste of money. But, mine sometimes have iffy/loose connections, and I do wonder how much that affects sound. Today I came across an article about making cables and decided to go for it.
So I bought bulk balanced cabled, male and female xlrs...then some bulk unbalanced cable with TS 1/4" (since I record on a 244 4-track sometimes, and it only takes unbalanced 1/4).
From what I read and looked at on youtube, this is simply a matter of soldering the cable to the xlr.
Has anyone done it? Any major challenges or advice?
you don't have to use external flux but it is easier and you will use less solder and get cleaner joints. the wet sponge works great, plus you can always just sling off the excess
