A
ayoung240
awesome job, I like what you've done!
I like it a lot! But apparently the definition of 'better' is open for debate. Arcadeko's corner panel with the 45º angles is more efficient per cu ft of rockwool/oc70x than a superchunk. The material in the very inner corner absorbs a lot less than the material in the deko trap that's a foot away from the corner. But that little inside corner DOES help a little, so technically the superchunk with the same front face dimensions will perform better. But you might be able to make 3 deko 45º corner traps with the same material as 2 superchunks, and deko's 3 traps will definitely absorb more. Deko's traps take the most inefficient material of a superchunk and move it farther out to a location where it can do more good.
To optimize that equation is the question.. given 1 case of oc703 or whatever. 4x2x1'=8 cu ft - what dimensions to make the traps to use all the material and get the most absorption. I dont do math this late but it's something to think about.
And yeah it's about the most efficient use of material, I can cover an entire 8 foot corner with 3 sheets of insulation. A superchunk trap would only have a 16" face using 3 panels floor to ceiling (each is 32" tall triangle-cut and stacked), the panels on the other hand have an 18" face.
they are also a hell of a lot easier to build and move around!
they are also a hell of a lot easier to build and move around!Density: for superchunks, which have a greater depth, ordinary cheap insulation is better. For panel bass traps and broadband traps where depth is much shallower then higher density (6pcf) insulation performs better. In the US, Owens Corning 705 is the preferred dense absorption material. There are Roxul Safe 'n' Sound and Knauf Ecosse equivalents.
Who has the capacity to do an actual corner recording? Build two corner absorbers, and test them and SPL them?
Is there any kind of benefit to building a superchunk with back walls?
Or should the front and the two back sides be fabric and breathe?
Not a jack man. A good question. Basically it is a design where layers of dense insulation is stacked, in horizontal slabs, vertically in a corner, completely filling the corner diagonally. Did that make sense?
