Yeah Buddy, and the dubious smell entertainment! Knew this would come, I'm dubious as well... but determined.
And we'll see how far that gets me.
First explaining the end goals a little.
I would like to have a room I can do some critical listening in. Maybe record a little guitar, and possibly some scratch or demo vocals. I'm not doing the post production for Avatar 2 and I'm not trying to rebuild a room outta blackbird studios. I've got an 8pre audio interface and a duet I use with Logic 9 on my macbook to record and still haven't upgraded my entry level monitors (Event ALP5's.)
Because of that, when I mix I switch between those, and
my DT990Pro cans quite often (earbuds too.)
I'll probably never try to record drums in there unless I'm just screwing around.
I've got carpet in the room already and I'm not allowed to pull that up.
All I'm really trying to do here is make the room acoustically sound as good as it can, because I can't cut into the walls and it's the only room I've got to build in.
So MDLA I just did the room mode calculations because I just took measurements. (I actually don't have the keys to this place yet..... Friday I get keys.)
So the realtor took me in so I could measure.
I have a little more time now to talk so I'll say a little bit more about how much I'm really trying to bite off here, and I guess we'll see if I've got the teeth to chew it.
I was a big nerd in acoustics classes so some of this stuff isn't new to me (none of the concepts or equations are, a few of the practices are..)
The calculation of the room modes is really just to give me something to do while I'm waiting around to get in there.
The proof in the pudding will be when I get in there and here's what I'm intending to do:
Set up my monitors and a software oscillator. Set my SPL to a dBC (
Thanks MiroSlav) and I'll record the readings ascending in semitones from 20Hz to 20k.
If I have some indicators that I should have standing wave issues below 500Hz that aren't showing up in the readings. I'm going to chalk that up to my 5.25in monitors and assume that if I upgrade my monitors I might run into something (stay safe assume the worst right?)
I'll do this at the listening position, then at three other places in the room, one near the back wall. The other two, places I may consider setting up mics.
Once I have all the data for where the quirks in my room are (in Hz.) I'll make the final decision on what insulation to buy for trapping.
For what makes logistical sense right now I'm thinking that I'll put bass trapping from floor to ceiling. in the to corners behind my work desk. I'll also put traps horizontally where the ceiling meets the back wall, in the two corners (not all the way across.)
I don't know as much about bass trapping as I would like to, I haven't ever done it before. I know about frictional diffusion and absorption coefficients but I'm certainly no guru on placement or knowing how much should be used for what sized room (I understand the smaller room, the more you need.) But after building it, I figure I'll let my ears and the SPL meter be the judges.
After all that madness I'm intending to build some diffusion. Like seen here:
07734
out of a ceiling tile as a base, then ply, pine 2x2's cut to random lengths.
Place these strategically to try to get rid of some early reflections.
More on making diffusers and some of the specific problems with my room for this later.
But I have an large bookshelf I was intending to use as a back wall diffuser instead of treatment meant for treatment.
After all this, I'm hoping to start piecing my gear together in a fashion that gives me the best access to all of it and makes some logical sense (as supposed to how it is now, half of it being in the closet..)
I don't have a closet in the room to stick things that hum, and honestly I don't even have a rack yet, although it maybe getting toward time to buy one.
See what a newb I am guys? THIS is why I joined the forum. And, intend to spend lots of time talking to the folks here.
So give me your critical thoughts, but please, gimme a little encouragement if you've got any to spare.... I need it.
So play nice (Stealth_prod
) I love writing and recording and twittling the knobs and faders so I'll do it wherever I am, and if there's an old lady who doesn't like it on the floor above me, I make a mean apple pie and I'll bake her more than she can eat, and I'll walk her little yippy shaky dog because I'll do whatever takes to keep on making organized sounds.
Next I'll post the gear that I intend to shove in here.
But really I need any experienced guidance you all can offer on the treatment thide of sings. (Catch the reference?)
