W
Wbrownj
Hi all, I am new here and this is my first post so I hope you can help.
I have a br900 and have just bought a 2nd hand br1600. It is fine but there are two problems
1) a few of the buttons, for example the return to zero (|<<) and the yes buttons are not very responsive when pressed. They work but some times you need to press them a few times for it to register. It does not seem that the buttons are mechanically sticking or jamming and pressing them feels just like pressing any other buttons. It is more like the contacts of the switches need cleaning. Has anyone any advice on this? Also is it possible to safely remove the casing in order to access the contacts and perhaps spray them with contact cleaner?
2) when I plug my fender strat or tele into the br1600 front or back jack it seems to generate an unacceptable amount of buzzing background noise. I kind of got a bit of that on my br900 but only when using mains power... Batteries were ok. The buzz on the br1600 is worse and there is no option to use batteries. I use it in my home and there are no things like flouredcent lighting to generate interference. Any suggestions are really welcome. Should I be earthing the br1600 and if so, to what?
Thanks in advance.
Jonathan
Thanks in advance.
Jonathan
