SouthSIDE Glen
independentrecording.net
Actually, in this case it kind of is. "Phase inversion" not only exists, but it is a very common principle in physics. In this case, phase inversion in the sound pressure yields an inversion in electrical polarity. Or put the other way, an inversion of electrical polarity yields an inversion of phase in sound pressure.fazil said:Phase "invertion" or "flipping" is not the signal upside down. Phase invertion DOES NOT exist. You should understand the differance between phase and polarity.
It seems like a stupid matter of terminology but it's not ...
The distinction is that "polarity" usually does not become involved as a technical term untill the sound waves are transduced into electrical current, whereas "phase" can be used to describe properties and events in any physical medium. While sound waves can have "positive" pressure and "negative" pressure as related to the air pressure of an otherwise silent room, these pressure waves are usually not said to have a "polarity". Yet they do cause things such as "phase cancellations" and "phase reenforcements" and the like.
(And, BTW, as a very hair-splitting sidebar, out of curiosity I did some research before coming back to this thread, and I was wrong about one thing; indeed phase shifts can be applied and measured to irregular waveforms like audio recordings. The math is not limited to simple periodic shapes like sine waves or square waves. But to introduce that here is just complicating matters even worse than they already are
.)The important thing that needs to be understood here is the action that is taking place. The inverted phase/polarity between a top-miked drum signal and a bottom-miked drum signal is due to the "mirroring" of the sound pressures on one side of the drum skin vs. the other. When the air pressure goes "positive" (becomes denser) on one side of the skin, it more or less simultaneously goes "negative" (becomes thinner) on the other side and vice versa. Their "phases are inverted." This is not the same thing as a time shift or delay that throws the two signals "out of phase". The actual mechanism is what's different, and understand that mechanism is what's needed to avoid the confusion between "phase shift" and "phase inversion" (or, once in the electrical realm, "polarity inversion.")
End of my Mr. Whoopie impersination...
G.
