R
robn
A Muse Zen
I started building a home studio about 2 years ago but got sidetracked <insert Ran out of money /insert> I've got a tiny bit of money now and I want to finish up.......would like some advice on things such as upgrading or building new DAW, audio interface, software upgrade, studio design, etc......
Total budget is just $3000 so please keep that in mind....
Here's my present setup:
Studio- built in the not-really-build "bonus room" above my garage.....house is 2 story, one of the upstairs bedrooms is right next to the studio but both my daughters are older and have moved out. Here are a few old pics:
Rough design:
There is insulation in all the walls and ceiling now
Just an example of the interior walls....also now has insulation in it
I need to finish framing the interior new wall.......then put 2 layers of 1/2" sheetrock on all walls/ceiling....tape and bed, texture, finish hooking up electrical (most of it is done), put in new floor, put in track lights.....the HVAC has already been tied in......
Studio questions: Should I build a separate control room or not? Space is pretty limited. Also, will 2 layers of sheetrock help that much?
Software is Sonar....right now I have Sonar 5 but am considering upgrading to Sonar 8. My present DAW was put together about 3 years ago:
XP Professional
P2 2.4 single processor
Gigabyte P4P800
NVidia GeForce2 MX400 64MB
2 Maxtor IDE 120GB each
1 GB RAM
Audigy2 SB Card
One of the bad limits here is a max of 2GB of memory that the board will support....which would then pretty much rule out any purpose for 64-bit OS. Second, the video card memory is low. I believe the board will suport 100MB SATA drives. I would also like to drive 2 monitors which I'm not sure how I could do that.....
Question: go to Sonar 8 or stay at Sonar 5? Build a new DAW (I could use the power supply, case, DVD/CD drives, and Audigy SB Card from the old DAW). I already have a 2nd monitor
Audio interface.......I just bought a Digitech GNX4 mostly for guitar effects but it does have an audio interface.....since I haven't tried it yet I don't know whether it would be sufficient......
I have an old CME UF70 76-Key Controller for MIDI so I would be probably using alot of Sonar's soft synths
Plenty of guitars
A few mics.
Marshall ValveState 50W amp
Event PS5 monitors
How would my $3000 best be utilized here? Sorry for all the questions but I'm just trying to get the most bang-for-the-buck.....the studio use would mainly be just for me and more in a songwriting/composing mode.
Thanks!!!!!
Rough design:
XP Professional
Gigabyte P4P800
1 GB RAM
Audigy2 SB Card
Plenty of guitars
A few mics.
Event PS5 monitors
Thanks!!!!!
One room works great for your intentions. You just have to minimize room noise, like the computer, HVAC, etc... It's easily doable with some forethought.
What I will probably do is get the studio built and then if I have any money left over upgrade the PC or just build a new one.....
There is no vertical support in middle of the garage.....there is a 2" X16" joist across the middle of the attic (studio area), one end sits on an outside wall, the other on an interior wall. There are 2"X12" joists between these which make about a 7' maximum joist span.
