Best nylon classical strings?
  • Thread starter Thread starter CanopuS
C
CanopuS
Amateur music since 1847
Hi, I've just dug up my brothers old nylon guitar, and it's actually pretty good, but desperately in need of new strings. I was wondering if you had any recommendations for brands etc? Thanks! :)
I like the Savarez (sp?) strings. They're a couple bucks more than other brands though.
Savarez are the best, but many players also like the Lisa strings (good luck finding them though). Augustine, GHS, and D'Addario also make a fine quality string.
Light
"Cowards can never be moral."
M.K. Gandhi
I've been using D'Addario's for the past 22 years.
They might not be "the best" but they have served me well.
Anyone here ever tried gut strings? I've always wondered how they sound, how long they last, how much they cost, who carries them...
If you are using it for folk/blues/pop as opposed to classical, then I recommend D'Addario composites. They cost a little more but they last 2-3x as long and the sound is bright, full, balanced.
Lately I've been using the bulk strings (usually made by Martin) from stringthis.com - about $12 for 4 sets. They come in sealed plastic and aren't rolled up and seem to be fresher.
Savarez strings are more sensitive to temperature and the wound strings will come apart in temps over 100.
If you are letting your guitar get that hot, you probably have problems other than your strings unwinding to worry about.
Light
M.K. Gandhi
I use d'addarios. I put a cheaper set of string on my classical right before a recital and they screwed my guitar up- pulled the action up and bowed the neck which made everything horribly out of tune. My recital went horrible. The next week I pulled off the cheap strings and put a set of normal tension d'addarios on and it fixed the problem. There was a huge difference in the quality of the tone too. If you have a truss rod, I would get the hard tension, but if not I would use the normal tension.
Cool I just bought a set of D'addarios. They keep going out of tune, but they SOUND good :) Thanks all (And yes I know it will go out of tune after just putting em on :D)
