B
bad intentionz
current im looking at the samson 5' ribbon moniters any ideas or how are the samsons
bad intentionz said:i was looking at the bx5as or the event tr5s any ideas on those?
I second that. The Rubicon 6 and KRK RP6 are both good and better than Wharfeshits.apl said:Get at least 6" woofers.
xstatic said:"better" is certainly a matter of opinion. A lot of people here really like the Event line. I personally do not. I also don't like the KRK RP line either. If it were me i would be looking into something like Tannoy Reveals in that price range.
People here get that, dude, relax. They're trying to give you their opinions as to the best option. Did your post not read "Best monitors for $350"?bad intentionz said:these are going to be my frist moniters and im not looking for TOP LINE PRO SHIT
Well, waste your money on cheap monitors and end up buying better ones two years from now and waste your money. Why don't you just get serious and get some better monitors at the beginning? If you are are NOT that serious about mixing, then buy some $200 monitors and see if you like it.bad intentionz said:these are going to be my frist moniters and im not looking for TOP LINE PRO SHIT
Yep! Indeed, buying used is also a good insurance in case you actually don't like mixing that much. You can resell for about the same price you paid.apl said:Yeah, those top line pro monitors will set you back $10,000 easy.
TheDewd makes a good point. If you get something cheap to get you started and you get way into, you'll want better stuff later. If you buy used you'll probably be able to get most of your money back when you upgrade.
So I think you should invest in good 6 or 8 inch monitors around $500-$600 so you'll be happier in the long run. Check some used stuff too, might be quite interesting.bad intentionz said:im serious about mixing i been mixing/ recording for almost 2 years just i never had moniters. its just that money for a 16 year old is hard to come by now adays
