L
LongWaveStudio
Abbott, i dont think anyone said the composer was better than the RNC. that's down to personal choice and whether you like the sound of the composer or the RNC.
the composer will be better for you if.. you need gates, need a peak limiter at the end of the compression stage, need side chains (does the RNC have this..) or if you need 2 mono channels.
correct me if im wrong, but the RNC will only work as 1 mono compressor, or stereo but with controls for only one side.
the RNC is good if you're looking for a more transparent sound as Bruce described it as.
go and try them out if you can, that's probably the best advice you'll get.
-Romesh
-Romesh
