A
acorec
Banned
TexRoadkill said:The same way many behringer bashers haven't used behringer many behringer supporters have never used anything better. I've messed around with some of the mixers and have heard stuff done on them. Their mixers will generally do what they are supposed to do but the sound is usually thin and slightly muffled.
The problem is that the differences between okay and great sound are a lot of small things added together. You can make passable recordings on a behringer but you will be far from killer sound. For a few hundred bucks more you can be much closer.
Good post. I will only say that I have worked on some of the best consoles made. In the 1000-5000 range, we on this BBS are fighting for better sound with limited options out there. I have the Behringer MX8000 because I needed a cost effective board for my home studio. I worked in pro studios for a while and see no difference between Mackie and Behringer. When you use the top consoles, you will understand how little difference there is on any board that is less than 5000. Really, for my hobby, I will never afford the next step up. It is not a couple of hundred, but many thousands away. I just do not need it. But, a really good board, if you must have it, will be in the 10,000 range. This is when you start to get NOT more channels, but GOOD channels.
it's all in the money, that's all, the rest is pure BS 99% of the time...IMHO -0.2's worth...
