Beatskillz released Sampler Emulator - SampleX
  • Thread starter Thread starter BfromB
BfromB
BfromB
Visit beatskillz.com/samplex for more Info
( Get it now at $39 - Reg Price - $69 )
About SampleX
In today’s advanced age of music tools that seek the “cleanest”, most “perfect” sounds, there has suddenly been a desire for the “Gritty” sounds of the machines of the past.
Once such quest has been the acquisition of old, primitive samplers and sample drum machine. This has increased the rate of these machines to 10s of thousands of dollars.
The sound that producers and artists seek in these boxes is usually the low bit rates and sample rates resulting in an “aliased” sound or “artifacts” as we now call them. These limitations of the vintage machines have now become very desired and sought after sound. Just sample rate reduction and “Bit crushers” have yet to actually sound like old machines.
Our team at Beatskillz went on a quest to study the actual circuitry and found each and every step right from the A/D converters, preamps, analog and digital filters and processes involved to recreate each stage and bring you a plugin that can not only emulate a sampler but many, and also lets you design your own sampler or vintage chip!
The Sample Rate Interpolation system that we have built-in DSP, lets you dial in any sample rate from 96 kHz to 2 kHz. You can also ” type ” in the values!
We have also done a very accurate emulation of a well-known Ladder Filter with Resonance, this gets you the “Warm” Filter sound of a very desired analog synth. We have also carefully emulated the input drive of the S900 to give you all the parameters needed for multiple variations of the sound!
Features:
  1. Emulate any Vintage sampler by using the key controls which actually shape the sound of those units
  2. Create the true desired “aliasing without changing the pitch of a sample with the Shift control
  3. Accurately modelled Input Drive of the s900, a major part of the vintage sampler sound being sought.
  4. An accurate model of the famous Ladder Filter with resonance!
  5. Dial-in any sample rate from 96khz down to 2 kHz, reduce bit rate up to 4 bits
  6. Blend in the dry sound and have total control on the amount of “effect”
  7. “Type” in the values for more accurate control and sound shaping
  8. Multiple carefully “ear” matched vintage sampler emulation models included in the presets
