Zoom R24 Twenty Four Track Digital Recorder/ Workstation
  • Thread starter Thread starter B_A_Star
B
B_A_Star
Barely used Zoom R24 Multitrack Recorder, Interface, Sampler. This unit records to SD cards, can be used as a control surface with popular recording software, and has a built-in sampler. This would be a great starter unit for someone interested in recording. Here's a brief overview:
The R24 provides 24 tracks for recording and playback (up to 8 tracks can be recorded simultaneously) in full fidelity WAV format (16 or 24-bit, at 44.1 or 48 kHz sampling rates), making it ideal for both professional production and for use as a musical sketchpad. Battery operation allows for field recording and enables you to capture your musical ideas quickly. You can connect external microphones or line-level sources directly to the R24 or use the built-in stereo mic pair for minimal setup. You can also plug instruments such as electric guitar or bass right into the R24. When your multitrack recording is complete, you can use the R24's internal mixer, complete with real faders, equalization, panning, and more than 100 built-in DSP effects--including amp models and mastering effects like multi-band compression--to create a stereo mix with studio-quality sound.
For more information, please visit: https://www.zoom-na.com/products/st...oom-r24-recorder-interface-controller-sampler
It has only 10-12 hours of use and includes all the original accessories:
USB cable for interfacing with computer-based DAW software (Control Surface or Audio Interface)
1 GB SD card
2 GB USB drive with drum samples
Driver CD for use as interface
Cubase LE5 DAW Installation CD (Unregistered)
Power Supply
User Manual
Original Box
Asking $300.00. Negotiable
