Bass Traps In Corners
  • Thread starter Thread starter Olijanovi
O
Olijanovi
Is it the same thing as the Broadband Absorber? And I simply shape them into triangles to fit the corners of my room? Secondly, do they need to be from the floor to the ceiling? While were at it, what do I put on the ceiling? Should I hang a blanket? My ceilings are in cement.
Thanks!
It depends on what type of bass trap you want to make, there's a few different kinds that people use. The first is essentially a panel, much like a broadband absorber, but with much thicker insulation. Usually anywhere from 4-8 inches thick of as apposed to the 2in thick panels of a broadband. That extra density from the added insulation allows the absorption of lower frequencies. The air gap behind the panel is kind of like a small resonance chamber and a lot of people believe because of that, they work better than the other methods.
One other is what is known as, Super chunks. This is where you would cut the insulation into triangles and stack them, filling the corner completely with insulation.
You don't have to make them floor to ceiling, frankly that gets expensive pretty quickly to do every corner. If you have the budget to do it, do it, if not there's an alternative. In relation to your mixing position, you can have the center of the bass traps at ear level.
If you cant afford to treat the corners floor to ceiling right now, then later you can add on "triangle" bass traps, I'll post a pic in at the end of the post, and use those for the tri-corners at the ceiling and floor.
For the ceiling you generally have a "cloud" absorber over the mixing position and above a drum set. Don't just throw a blanket up there.
Tri-corner traps:
Great, thanks for the quick reply. As for floor to ceiling, I don't see a huge difference in cost since I'll be making them myself. + thanks for the traping my room thread @ Dogbreath
Will those traps enhance the quality of the recording? I am not 100% looking to mix... I am mostly looking to have a decent recording room.
As to the recording (tracking) aspect, I noticed a difference on my first tracking session. Drums were first and I could hear the difference with the punch and the clarity. Almost....almost like my older sessions were smeared just a skosh. Hard to explain but yeah, I noticed a difference.
