Ford Van
Banned
stash98 said:So what you are saying is that if I got a clean transient on each track it still wouldn't matter?
So the only solution is to slide the amp track round until it sounds best.......there has to be a better way.
Better way to what? Isn't the idea of using two tracks together to make it sound different than one track?
The concept is quite simple. You do things to the audio to make it sound the way you WANT IT TO SOUND.
A lot of people go around advocating that you should time align your overhead mics with the snare mic on a drum kit. Now, sometimes, this can help enhance the sound, in certain types of productions. Often though, I find that lining up the snare transients on the overhead to match the snare mic takes all the liveliness out of the overall drum sound. The depth of the sound scape is much less, and often the cymbals sound dull and lack shimmer.
Other times, doing this fattens the snare sound and gets rid of harsh phasey sounding cymbals.
I cannot advocate doing this as a rule. I TRY IT every time I mix drums, but I have to honestly ask myself if it actually makes the drums sound better or not! Sometimes it does, sometimes it doesn't. Until I try it, I don't know.
I have found that I can shift them to be not quite perfectly in phase, and still retain the shimmer on cymbals and what not, but also fatten the snare. So, sometimes, a bit out of phase works well!
Your distorted bass track will not have a well defined attack and decay like the DI signal will, so, you are not going to be able to line things up based upon the "look" of the wave form. What I have been trying to say is that it really doesn't matter how they "look", it is how they SOUND together that you should concern yourself with. Shift it one way, yeah, you get more low end possibly. Shift it the other way, you get a sharper attack and grind which may sound REALLY FUCKING COOL! You don't know until you experiment and have a clue as to how you want the bass to sound for that song!
