M
mikoo69
I just need to understand the basics of a recording rig I want to put together.
The goal is to do 8 Track 1/2" analog recordings of live bands. I will not be doing any punch-ins or overdubs at this point. Simple mixes...
I bought an Otari MX5050 1/2" 8 Track Machine.
I want to be able to track a band. Then once the band is tracked, I want to mix the recording, using a couple of outboard units (an RNC compressor, maybe a Great British Spring Reverb). Just a basic mix, with a couple of outboards to help it out.
From what I understand (please correct me if im wrong), this is the process:
1) I will have 8 mics into an 8 channel mixing board and get levels. The goal here will be to get the best possible sound based on mic placement alone. Once I am happy with the sound I am hearing monitoring off the mixing board, I will record the band onto tape by taking direct outs from the mixing board into the 8 inputs on the tape machine.
2) Once the recording is complete, I will connect the outputs of the tape machine into the inputs of the mixing board. During playback, while monitoring through the mixing board, I will EQ, pan and send certain things through AUXs (compression, reverb, delay) for the best sound. Once I am happy with the sounds, I will connect a 2 Track 1/4" Deck OR a 2 track A/D converter (if i want to go into digital) to the 2 outputs of the mixing board. I will do a final playback of the Tape machine, hit record on the 2 track deck OR DAW, and automate levels in real time from the faders for anything that needs level automation, including fade outs/ins, etc.
IS THIS THE GENERAL IDEA? I AM COMPLETELY NEW TO THIS SO IF I'M OFF THE MARK, PLEASE LET ME KNOW?
Also, what would I do if I want to mix in digital? Would I just get good levels to the tape machine, then connect the 8 outs of the tape machine to 8 inputs on a Digital Audio Interface, set levels and record it to the DAW, then mix in the box?
I appreciate any guidance (sorry for being such a layman, I am new to analog recording)
RIGHT?
