Secret Clubhous
I origninally posted this in the Cakewalk forum but got no response, so I thought I'd try it here.
FYI, I'm running XP Home & Cakewalk Home Studio 2004 on a 22khz AMD PC w/120 gigs hard drive & Tascam US-122 as interface/sound card. It kept crashing intermittently, but only in that application.
So, after having numerous problems, I just had a master programmer check it out. He spent 3 hours diagnosing, cleaning, defragging & optimizing XP. When I tried to playback some files to test it, I could hear the MIDI tracks playing as usual (thru the MIDI keyboard) but can not hear any audio. There are plenty wave forms in the audio tracks, they are not muted, & it appears to be playing.
The US-122 is configured correctly in Options/audio & Global as well as in Windows Hardware Devices. The driver is 3.2.4.0, which I think is the latest one. Everything is connected properly as far as cables, etc. The junky onboard sound card is disabled.
Before this major tune-up of the OS I never had this problem with audio. Is there some little tweak or setting or dll somewhere that we have missed, that we need to change or enable so I can hear the audio? Could some key component of the program, OS, or interface have been deleted in the tune-up?
The machine had extensive bugs, mixups & nasties from the net all thru the OS, which were fixed Previously I had done the optimization tweaks on the musicxp.net website, not really understanding some of them, & I wonder if something was misplaced or turned off inadvertently? Should I roll back XP to the "last known good configuration"?
Cakewalk tech support said to change from ASIO (which I had been using) to MME. I tried that & also WDM. After adjusting the buffer I could hear audio but the program would not record. & why would I want to use MME, or WDM for that matter? Aren't those driver modes lower quality than ASIO?
Any insights will be appreciated! Thank you
—yes, that is a given.
